| Maestro II _ HQ - Pimp per PAW :-) | |
Guest Invité
![avatar](https://2img.net/i/fa/i/avatars/gallery/Animaux/Canard_bb.jpg)
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Maestro II _ HQ - Pimp per PAW :-) Ven 24 Aoû 2012 - 22:04 | |
| Here you go to enlarge this image:https://picasaweb.google.com/PAW211271/MaestroIIHQPimpPerPAW#5779631244875316946 Here it goes to the German thread:http://www.drachenforum.net/forum/ Maestro-II-HQ-Pimp-PAW-t75918.html
![Aller en bas](https://2img.net/i/empty.gif) | |
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Re: Maestro II _ HQ - Pimp per PAW :-) Ven 24 Aoû 2012 - 22:15 | |
| hi paw could you tell us what are the difference between the old and your new version in fly ?
thanks.
Guest Invité
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Re: Maestro II _ HQ - Pimp per PAW :-) Ven 24 Aoû 2012 - 22:47 | |
| Kite has more precision, control and trickpotential :-) |
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Re: Maestro II _ HQ - Pimp per PAW :-) Sam 25 Aoû 2012 - 13:36 | |
![Brunodu59](https://2img.net/u/4211/91/45/55/avatars/302-18.jpg)
Inscription : 26/09/2011 Age : 55 Localisation : Armentieres (59)
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Re: Maestro II _ HQ - Pimp per PAW :-) Dim 26 Aoû 2012 - 0:07 | |
| and that it was the first kite on which I flash
Thank you for the info PAW | |
Guest Invité
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Re: Maestro II _ HQ - Pimp per PAW :-) Dim 26 Aoû 2012 - 21:55 | |
| Just want to help people that do not have enough money for a good kite |
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Re: Maestro II _ HQ - Pimp per PAW :-) Lun 27 Aoû 2012 - 7:23 | |
| Good initiative PAW thank you again | |
![kalamical](https://2img.net/u/4211/91/45/55/avatars/128-38.jpg)
Inscription : 17/06/2010 Age : 50 Localisation : 62 - pas de calais - Carvin
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Re: Maestro II _ HQ - Pimp per PAW :-) Lun 27 Aoû 2012 - 9:05 | |
| - PAW a écrit:
- Just want to help people that do not have enough money for a good kite
it's very nice i like your schema with photo and many details, well done ! | |
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Re: Maestro II _ HQ - Pimp per PAW :-) Lun 27 Aoû 2012 - 11:42 | |
| Hi Peter,
Just a small clerical error for the lower spreaders, you wrote "lower spreader to Skyshark Nitro Gold", I guess you mean Nitro STD, Gold is for Aerostuff...
Otherwise, thank you for sharing. |
JL
![JL](https://2img.net/u/4211/91/45/55/avatars/260-56.jpg)
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Re: Maestro II _ HQ - Pimp per PAW :-) Lun 27 Aoû 2012 - 12:29 | |
| I guess he means Nitro Strong (with the golden print).
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Re: Maestro II _ HQ - Pimp per PAW :-) Lun 27 Aoû 2012 - 12:36 | |
| Yes ! You're right, this should be that... |
Guest Invité
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | |
Guest Invité
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Re: Maestro II _ HQ - Pimp per PAW :-) Lun 8 Oct 2012 - 21:23 | |
| When the Maestro II is changed, which only takes about an hour, the kite: - has like no oversteering - is slower - is way more precise - has a bigger windrange in both upper and lower - handles bumpy winds better - is more stable in backflip and fade - is more easy to trick - has more overall control - does way more tricks - makes more noise ...all this is, with the materials of the original kite, after the modifications ! If you want to use better materials, then use the upgrades step by step, it gets better & better... |
Guest Invité
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Re: Maestro II _ HQ - Pimp per PAW :-) Mar 23 Oct 2012 - 22:12 | |
![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | Sujet: Re: Maestro II _ HQ - Pimp per PAW :-) ![maestro - Maestro II _ HQ - Pimp per PAW :-) Empty](https://2img.net/i/empty.gif) | |
